after the last update Fusion does not show any projects anymore
the dashboard area is blank!
I signed out and singed in
I restarted the app to fix it
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
You may try using the Clear User Cache command the next time you run into this issue.
I hope that helps! Thanks!
Claas Kuhnen
How many projects are shared with you? Also, how large is your the ~/Library/Application Support/Autodesk/Autodesk Fusion 360/BrowserStorage_login.dat file?
Claas Kuhnen
I think you have to drill down into an ID folder unique to the user located inside of the Autodesk Fusion 360 folder to see the browserstorage_login.dat file. Sorry for the confusion.. 🙂
