I working with the lamp tutorial and I made a spline of the chord but i realized later on that the sketch plane was on the edge of the lamp neck instead of centered so when i created the body its on the side.
Instead of redoing the sketch - how can I move the sketch to another or new plane and let all the following actions go with it?
You may use the redefine command (right click on sketch in model browser) to move a sketch to a different plane. See the below ScreenCast for more detail.
I hope that helps. Please let me know if you have any questions.
actually realized it wasn't really the plane i had to move but location of it. the sketch was attached to the neck sketch profile instead of midline. I moved the body instead to place it correctly but it still isn't as clean as i would like it because now the sketch doesn't conform to the body.
Could you post a screenshot or sample model to this forum thread? It would be a big help!
