If I have a sketch that's in the right place except for one line, is there a way to just move that line? If I right click and move, it moves the entire sketch.
In this picture, the bottom edge of the sketch is almost but not quite lined up with the edge of my body.
Solved by innovatenate. Go to Solution.
The other sketch lines will move based upon the existing sketch dimensions and constraints. I'm not sure that you'll be able to align the edge of the body and a sketch line exactly with the move command. A better solution may be to use a sketch constraint command, coincident constraint, to line up the end point of the line with the edge of the solid.
I hope that helps! Let me know if you have an questions.
