I'm modifying a face in Scuplt mode, but I don't want to rotate the face from where the manipulator is. how do I move the manipulator itself to center on where I want to be rotaing from?
Solved by Phil.E. Go to Solution.
You can adjust where the manipulator sits by using the re-orient tool. There are limited options for placement: center of face, vertex, center of edges. Give it a try!
When you start Edit Form it should be on screen somewhere.
Thanks Phil, I finally did find it. DId not see your image when you first replied beacuse the screenshot did not show in my e-mail. Just saw it now.
