Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
missing step export - is ignored
13 REPLIES 13
Message 1 of 14
cekuhnen
601 Views, 13 Replies
here is another shortcoming in the export part of Fusion,
now it ignores doing a step export, but does all others fine
https://drive.google.com/file/d/0Byzv_NlyKp_2UHB1b09iZHdLbFk/view?usp=sharing
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
13 REPLIES 13
Message 2 of 14
Phil.E
in reply to: cekuhnen
I'm using the knife data set you posted in a recent CER report, if that's the same one, and I can export STEP.
Did you try restarting Fusion or your computer?
Is it just this data set?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 14
cekuhnen
in reply to: Phil.E
I did test other files and STEP does not work with ANY file and Fusion build.
the web interface produces STEp files just fine.
Claas Kuhnen
Message 4 of 14
kingson138
HI, the video was a bit unclear on my side. Did you mean that STEP files could not be exported from Fusion directly unless you used the Web Export?
Kingson
Using Apple computers
Message 5 of 14
cekuhnen
in reply to: kingson138
From inside Fusion I cannot export any STEP file.
From the A360 web interface I can.
Claas Kuhnen
Message 6 of 14
Phil.E
Claas-
I cannot reproduce this issue.
Is it happening on all of your machines?
On a machine where you see this, can you export STEP as a different user?
Phil
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 14
cekuhnen
in reply to: Phil.E
nailed it that on my sides I can only export STEP to the downloads folder.
all other formats export fine to the desktop
https://drive.google.com/file/d/0Byzv_NlyKp_2QWIwSnAxQXo5S2M/view?usp=sharing
Claas Kuhnen
Message 8 of 14
Phil.E
The link reports that the file no longer exists.
Does this still happen after the update? I still cannot reproduce this on Windows or Mac.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 14
cekuhnen
I can make a new screen cast
Claas Kuhnen
Message 10 of 14
cekuhnen
And yes after a fresh new install it still happens
Claas Kuhnen
Message 11 of 14
gabriele
I tried to export in step format too.
Yesterday, was not possible, Fusion360 din't save the file.
Today I've updated to the Ultimate release and purchased the subscription. Now is possible to save in stp format. The file is created.
iMac 5K  - Yosemite
regards
Message 12 of 14
cekuhnen
After the update the step report still failed but after a restart of the computer s all worked.
Claas Kuhnen
Message 13 of 14
Hi Claas,
It seems to be the first launch of the product after an update kind of problem. As you mentioned once the machine or app is restarted the problem goes away. Please let us know if you see this problem again.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 14 of 14
cekuhnen
in reply to: Phil.E
let me see
nope restarted fusion on a different computer
exported step doesnt do it
IGES works
*Claas Kuhnen*
*(715) 309-9795*
*www.ckbrd.de*
*info@ckbrd.de*
Claas Kuhnen
