Missing Command Palette
12 REPLIES 12
Message 1 of 13
1164 Views, 12 Replies
Whenever I perform any task with a command palette, it doesn't load show up.  For instance, if I go to revolve a sketch: I select the face, but then I can't click on the icon to select axis because there is no window (command palette?).   So, if I do try to do one of these operations and go the upper left menu (three black lines), select view, and toggle the command palette...nothing.  If I try, resetting defaults....crash everytime.   I pay for this software and I have deadlines to meet.  I can't use this software if I can't use the command palette.  Please help!
Thank you for any info you can send my way!
Johnny Harris
12 REPLIES 12
Message 2 of 13
SallyYang
Hi Johnny,
Thanks for pointing out this issue. You can try clearing the cache files to get the command palette back:
   ~/Library/Application Support/Autodesk/Autodesk Fusion 360
And if you have sent the crash report to us, please let us know the email address that input in the CER dialog, so we can search and analysze the CER to make the issue resolved.
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Message 3 of 13
Uninstalled, cleared cache, run a cleaner software. Works great now....thank you
Message 4 of 13
AndrewSears
Johnny,
A few of us here have seen this happen before.  Unfortunately we are not able to figure out the cause.  My feature dialogs came back within a few minutes but I don't know what triggered them to show up.
If you run into this again, please try to document the steps you were doing right before the feature dialogs stopped showing up.  You should not have to re-install the product to get this to start showing up.  If this happens again try restarting the program first.
Andy
Message 5 of 13
quaverf
in reply to: AndrewSears
Experiencing the same problem tonight.  Command palattes are not visible.  For example, creating a new design, made a simple 2D sketch and selected the profile and then selected EXTRUDE.  The command activates, I get a directional arrow indication and the small numerical input window pops up but no command palette.  For clarification the palette is where I would make selections such as extrude type (join, cut, etc) and new body or new component, etc.  Have no idea what has changed since using the software last evening. I have closed the program and reopened to no avail. Suggestion on how to I resolve???
Message 6 of 13
deyop
in reply to: quaverf
I have experienced this behavior but often it is because I have disconnected a second monitor I generally use.  Whenever any UI element such as a command dialog is missing I have successfully brought it back by going to the dropdown in the upper left corner of the window and under View you will find an option to "Reset to Default Layout".  This has always restored missing elements.
Message 7 of 13
quaverf
My problem started after disconnecting my 24" monitor from my laptop.  Moved to a different desk and then launched Fusion without the external monitor connected.  Sounds like the same issue.  I tried TWICE now to Restore to Default Layout as you advice but Fusion crashed both times.  Looks like I will kill more valuable time tonight trying address another glitch.  Thanks in advance for any additional advice you might be able to offer.
Message 8 of 13
quaverf
Went back to the other desk, connected the 24" monitor and I get my command palettes back.  45 precious minutes lost out of another evening.  Definitely a glitch that needs some attention.
Message 9 of 13
quaverf
After reconnecting the external monitor and recovering the ability to see the command palette I docked the command palette on the RH side of the viewing window.  I then closed Fusion, disconnected the external monitor and moved the laptop to another location.  I launched Fusion and was able to open my design and have normal visibility to the command palette.  Seems to be a matter of how Fusion behaves to docked vs undocked command palette in this situation.  Hope this helps anyone else who might encounter this problem.
Message 10 of 13
deyop
Sorry for the frustrating experience.  There is a defect logged on this problem now.
Message 11 of 13
quaverf
Thanks for the feedback.
Message 12 of 13
michaelbuffington
I'm on a Macbook Pro running Fusion 360 natively in OSX 10.9.2.
I'm stuck with missing command palletes as well after disconnecting from an external display.
When trying to reset to the default layout Fusion crashes (not sure if it helps, but I sent the crash report with the ID of CER_95268738). I've yet to try clearing any cache found in ~/
Library/Application Support/Autodesk/Autodesk Fusion 360 as it's not obvious where the cache actual sits - there's a lot of stuff in that directory that looks like shouldn't be wiped out.
Unfortunately, I can't reconnect to an external display anytime soon - this issue essentially prevents the use of Fusion until I can find a workaround.
Message 13 of 13
Many thanks for posting the issue to us. I also encounter the disconnecting from external display when Reset to Default Layout. And I could fix the issue by re-launch Fusion 360. If that doesn't work to you, please try the final workaround----un-install & install Fusion 360, then the external display should be connectable.
The development group of Fusion 360 have already been aware of the issue and probably will resolve it soon.
I am very sorry for any inconveniences that caused by the issue. I hope you can continue work on Fusion 360 and communicate with us about your feedback.
Sally
Sally Yang
