Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
mirror not working correctly with off set plane
2 REPLIES 2
cekuhnen
282 Views, 2 Replies
offset plane is .25cm
but mirror result using off-set plane is .5cm
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
2 REPLIES 2
jeff_strater
in reply to: cekuhnen
Perhaps I am missing something here, but isn't this what is expected? You are mirroring the body about a plane that is .25 cm away from the body, I would expect that the mirrored geometry should be .5 cm away from the original. What result do you expect to see in this case?
Jeff Strater (Fusion Development)
Jeff Strater
Engineering Director
cekuhnen
in reply to: jeff_strater
shame on me - what a logic fail.
Of course you are right.
However on a side note, it actually would be nice if you could mirror the part and with the plane define where the mirrored part should rest
somewhat like a mirror / array combo.
Claas Kuhnen
