Active Contributor
LeonMF
Merging joints into solid body
123 Views, 5 Replies
12-26-2013 09:20 AM
I have a relatively simple design and I made some reusable components that I then assembled together with joints.  However, when I export the model using hte STL export from within the designer, the joint parts are all treated as separate items.  For example, when I slice the model using Cura, a simple rectangular body that has a joint in the middle would look like this:
However, I wan them to be one body so that the path looks like this:
A simple way would be to merge all components into a single body but my inexperience has left me with a lack of understanding how to do that.
Any advice would be appreciated!
Please use plain text.
Board Manager
schneik
Re: Merging joints into solid body
12-26-2013 11:20 AM in reply to: LeonMF
In the solid workspace in the modify panel is the combine command. I think that is what you are looking for to combine multiple bodies/ components into one.
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
Active Contributor
LeonMF
12-26-2013 01:34 PM in reply to: schneik
Thank you, that was it.  It was a little tricky as it sometimes rearranges parts when it merges but I got it.
Employee
Mike.Zhang
12-26-2013 06:46 PM in reply to: LeonMF
It'll be welcome if you can attached your model here, let us know what happened in your model about "rearranges parts".
We'll analyze it and give you some suggestions.
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
Active Contributor
LeonMF
12-30-2013 08:37 AM in reply to: Mike.Zhang
I went back and played with this some more and could not reproduce my problem. I will post an example if I am ever able to reproduce it.
On a related note. this does solve the problem but it requires me to go through the following process:
Export model -> import model -> combine model -> save as STL
or
Combine model -> save as STL -> promote previous version
This is a case where better model management would be nice. A clone model feature or something to streamline the process would be awesome.
Board Manager
schneik
12-30-2013 11:26 AM in reply to: LeonMF
Great, copy model from the dashboard is coming in the Jan update.
For now you can Right mouse click at the ver top node in the browser and do a save copy as... This will copy the design to a new name in the same project as the open design.  You can then open this design, merge the bodies and delete it when done.
Kevin Schneider
