I am trying to join the socket in the picture to the outside of cylinder tube at an exact dimensional location.
What is the best way to do this?
I managed to get the two pin ends to connect my making a small hole in them to snap a joint to. But this was easy because when you creat a hole it picks the center. So this will not work on this occasion, unless its possible to tell fusion exactly where to create the hole on the cylinder.
Solved by Dennis.Ossadnik. Go to Solution.
Hi pendlej,
I would suggest to create a sketch with a point on the outside of your cylinder tube.
You can apply dimensions to take control over your point.
After that use a joint to fit the pin and the cylinder.
I created a video here:
https://screencast.autodesk.com/Main/Details/da97d7e4-5643-4327-b3a6-45778f298fb7
I hope I understood correctly what you are looking for.
