loft fails because of no intersection of curve with a vertex? what?
8 REPLIES 8
Message 1 of 9
cekuhnen
385 Views, 8 Replies
I am not sure what the problem here is - should be an easy task to loft two trimmed edges.
file attached
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
8 REPLIES 8
Message 2 of 9
bob_holland
in reply to: cekuhnen
cekuhnen,
Can you provide me with the step to reproduce this.
The model that I is provided seems to be a little different.
Thank you.
Bob Holland
Autodesk Product Support
Message 3 of 9
cekuhnen
in reply to: bob_holland
made a side sketch
trimmed the gap open
tried to loft to close it
Claas Kuhnen
Message 4 of 9
innovatenate
Hey Claas,
Playing with the options, I find that the loft computes successfully if I use the Closed option in the Patch > Loft command, see below.
Let me know if that helps.
Nathan Chandler
Principal Specialist
Message 5 of 9
cekuhnen
in reply to: innovatenate
but a closed loft option for an open surface does not make sense!
the loft code here simply has a problem Alias and Rhino does it fine.
Claas Kuhnen
Message 6 of 9
innovatenate
I have reported this incident to development for further investigation. I agree with you, it doesn't seem like the closed option which according to the online help,  "Enable(s) to connect the first and last profiles to create a closed loft," should impact the behavior in this example. Thank you for your dilegence and for reporting this. As soon as I have any information regarding this issue, I will post an update here. Please let me know if you have any questions in the mean while.
Nathan Chandler
Message 7 of 9
cekuhnen
thanks!
Claas Kuhnen
Message 8 of 9
innovatenate
I just received an update. This issue should be address in the next update.
Thanks!
Nathan Chandler
Message 9 of 9
cekuhnen
yeah!
Claas Kuhnen
