i just wanted to create an air channel between the inlet part and the outlet. I tried doing this with the Loft command as i wanted to avoid to go into sculpt with object conversion and stuff (and as i'm not soo experienced in sculpting yet) but all i get is a loft error that doesn't bring me any further.
I've attached the file. The two faces i want to connect are the once that are facing each others so the "inner faces" like i would call it. Any idea?
Thanks in advance,
Helmi
Frank,
We can do this but it is not as easy as selecting the 2 faces.
Create a sketch and project the faces of the 2 components you want the loft to go between. You could use 2 sketches but I did this with a 3D sketch.
Now select the loft command and choose the outer closed loop profiles. This will create a FULL loft to start with.
Turn the sketch visibility back on.
Now repeat the loft command but this time select the inside and "cut".
Now you can use combine if you need this to be one body.
Andy
