i am trying to model a U-joint and get it to turn while the two ends are at different angles, as a
u-joint should, but cant figure out the correct joint set up for that, i have seen the tutorials but its
just not working for me, how do i ground both shafts on each end of the u-joint is the big question.
Anyone out there built one of these up, i would really love to watch the whole method to get it right.
Zach Wasil
You cannot grond both shafts. Mechanically that would not make any sense Both of your "forks" need to move in a bearing like the blue one you already have. The bearings should be grounded or assembled to something else tat is itself grounded.
File->Export
Select .f3d as format
Zip it up and attach to you next post.
