Process: Autodesk Fusion 360 [44803] Path: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360 Identifier: com.autodesk.Autodesk Fusion 360 Version: ??? Code Type: X86-64 (Native) Parent Process: launchd [316] Responsible: Autodesk Fusion 360 [44803] User ID: 501 Date/Time: 2014-06-29 19:58:11.837 -0500 OS Version: Mac OS X 10.9.3 (13D65) Report Version: 11 Anonymous UUID: E1805906-A2C7-57FA-5A8B-F78D2A0D2C60 Sleep/Wake UUID: 543E5296-4A50-442D-8411-3901851106E1 Crashed Thread: 0 Exception Type: EXC_BREAKPOINT (SIGTRAP) Exception Codes: 0x0000000000000002, 0x0000000000000000 Application Specific Information: dyld: launch, loading dependent libraries Dyld Error Message: Library not loaded: @rpath/Qt.framework/QtCore.framework/Versions/Current/QtCore Referenced from: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360 Reason: image not found Binary Images: 0x7fff6e503000 - 0x7fff6e536817 dyld (239.4) <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld Model: MacBookPro10,1, BootROM MBP101.00EE.B02, 4 processors, Intel Core i7, 2.7 GHz, 8 GB, SMC 2.3f36 Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020 Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020 AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (5.106.98.100.22) Bluetooth: Version 4.2.4f1 13674, 3 services, 23 devices, 1 incoming serial ports Network Service: Wi-Fi, AirPort, en0 Network Service: Parallels Shared #0, Ethernet, vnic0 Serial ATA Device: APPLE SSD SD512E, 500.28 GB USB Device: Hub USB Device: FaceTime HD Camera (Built-in) USB Device: Hub USB Device: Hub USB Device: BRCM20702 Hub USB Device: Bluetooth USB Host Controller USB Device: Apple Internal Keyboard / Trackpad Thunderbolt Bus: MacBook Pro, Apple Inc., 23.4
Solved by vnagy. Go to Solution.
Thanks for the help but I'm not going to be able to do these things on this machine so I'm out of luck.
Appreciate your time on this.
I am sorry to hear that.
May I ask why you are unable to try the second option? OS X makes it straightforward to non-destructively re-partition portions of your disks. Is it an authority or policy problem? This sort of feedback may be helpful in prioritizing case-sensitive file system support for the future.
Steven
If anyone is still interested... You can also circumvent the case sesitive file system problem by creating a new case insensitive file system image with the disk utility application. This way you don't have to repartition your drive.
- First check the size of your ~/Library/Application Support/Autodesk folder.
- Create the file system image at least a few hundred megs larger. (Applications/Utilities/Disk Utility -> File -> New -> Empty Disk Image)
Make sure that the format is not case sensitive, and is read-write!
After creating the image, OS X should mount the file system. If not, double click the disk image in the folder where you created it.
- Copy the ~/Library/Application Support/Autodesk folder onto the image.
- Delete the original folder.
- Create the Autodesk symlink in ~/Library pointing at Autodesk folder on your disk image.
You should be ready use Fusion 360.
This works on my 2009 unibody macbook, running 10.9.4.
Viktor
