Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Installer crashes OS X 10.9.3
23 REPLIES 23
Message 1 of 24
sports.racer
967 Views, 23 Replies
Process:         Autodesk Fusion 360 [44803]
Path:            /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Identifier:      com.autodesk.Autodesk Fusion 360
Version:         ???
Code Type:       X86-64 (Native)
Parent Process:  launchd [316]
Responsible:     Autodesk Fusion 360 [44803]
User ID:         501
Date/Time:       2014-06-29 19:58:11.837 -0500
OS Version:      Mac OS X 10.9.3 (13D65)
Report Version:  11
Anonymous UUID:  E1805906-A2C7-57FA-5A8B-F78D2A0D2C60
Sleep/Wake UUID: 543E5296-4A50-442D-8411-3901851106E1
Crashed Thread:  0
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  Library not loaded: @rpath/Qt.framework/QtCore.framework/Versions/Current/QtCore
  Referenced from: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
  Reason: image not found
Binary Images:
    0x7fff6e503000 -     0x7fff6e536817  dyld (239.4) <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
Model: MacBookPro10,1, BootROM MBP101.00EE.B02, 4 processors, Intel Core i7, 2.7 GHz, 8 GB, SMC 2.3f36
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (5.106.98.100.22)
Bluetooth: Version 4.2.4f1 13674, 3 services, 23 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Network Service: Parallels Shared #0, Ethernet, vnic0
Serial ATA Device: APPLE SSD SD512E, 500.28 GB
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Apple Internal Keyboard / Trackpad
Thunderbolt Bus: MacBook Pro, Apple Inc., 23.4
23 REPLIES 23
Message 21 of 24
sports.racer
in reply to: svelez
Thanks for the help but I'm not going to be able to do these things on this machine so I'm out of luck.
Appreciate your time on this.
Message 22 of 24
svelez
in reply to: sports.racer
I am sorry to hear that.
May I ask why you are unable to try the second option?  OS X makes it straightforward to non-destructively re-partition portions of your disks.  Is it an authority or policy problem?  This sort of feedback may be helpful in prioritizing case-sensitive file system support for the future.
Steven
Message 23 of 24
vnagy
in reply to: svelez
If anyone is still interested... You can also circumvent the case sesitive file system problem by creating a new case insensitive file system image with the disk utility application. This way you don't have to repartition your drive.
- First check the size of your ~/Library/Application Support/Autodesk folder.
- Create the file system image at least a few hundred megs larger. (Applications/Utilities/Disk Utility -> File -> New -> Empty Disk Image)
Make sure that the format is not case sensitive, and is read-write!
After creating the image, OS X should mount the file system. If not, double click the disk image in the folder where you created it.
- Copy the ~/Library/Application Support/Autodesk folder onto the image.
- Delete the original folder.
- Create the Autodesk symlink in ~/Library pointing at Autodesk folder on your disk image.
You should be ready use Fusion 360.
This works on my 2009 unibody macbook, running 10.9.4.
Viktor
Message 24 of 24
sports.racer
in reply to: vnagy
Awesome! Thanks.
