Hello Fusion 360 Team
When measuring objects, and there is more then one solution, one of the green distance arrows stays on the screen. Closing and reopening the model clears the marking.
I have an extruded, tapered circle, when measuring the 2 parallel faces, there are 2 distance markings, one in the center and one at the edge of the smaller face, closing the Measure dialog box leaves one marking (the one on the edge).
I saw posts on the forum with a similar issue related to the SpaceMouse, but I have no SpaceMouse.
Many thanks and kindest regards
Ludo
Solved by NicolasXu. Go to Solution.
Hi Ludo,
Thanks for reporting this problem and showing the details with screenshot. We have recently fixed a similar issue in the internal builds. I double checked your case, and it’s fixed. You should be able to see the correct behavior in next update.
Sorry for the inconvenience and please keep feedback coming.
