I would like to know if it is possible to import and modify a dwg file, and if yes, how? TIA
Solved by schneik-adsk. Go to Solution.
If the DWG has 3D solids. Yes. In the data panel upload the DWG.
If the DWG is 2D you can use the 2D data as sketch geometry to make 3D designs but you will have limited drafting tools to work on the 2D geometry.
