I have run in to this issue in two different projects, one that I used a downloaded SVG and one i created the SVG. Both times the image is significantly larger than what it was in InkScape. Is there a setting to correct this issue? Or do I just have to calculate the scale needed to get the right size and apply it?
Sean
Solved by rishivadher. Go to Solution.
Welcome to the Fusion 360 community!
See the below thread for potential answers to this question.
http://forums.autodesk.com/t5/general-fusion-360-questions/from-illustrator-to-fusion/td-p/5409283
Let me know if this doesn't answer your question and I'll be happy to investigate further.
Best Regards,
Hi
In Inkscape you put dimension in Inkscape of the object in px and remove the stroke, then you will have the correct dimension in fusion
best regards, Rishi Vadher
Rishi Vadher
Personal Page
Facebook | Twitter | LinkedIn
Is it possible for Fusion to scale SVGs correctly when importing?
If I want a logo to be 10mm wide, I need to scale the Illustrator art to be 10 pixels wide to get an accurate output.
I would like a more natural flow where I make a 10mm box in Illustrator and am able to import that SVG as a 10mm box in Fusion.
The existing workflow was very difficult to find and not intuitive.
