Hey all,
When I take this archive file and upload it, then try to import it into an existing Fusion file, it crashes Fusion.
This also happens with the original. This is on Mac, I haven't checked it on Windows.
I'm having the same issue with one of my components. It doesn't happen with other components, but the one that causes a crash does so every time I try to import it into a project. Fusion360 for me has been super unstable and seems to be getting worse and not better.
Luke,
The team is looking into it. Will get back to you shortly.
Steve,
Can you share your component which crashes on import. Also is the instability on just import or other workflows as well. If you can share your diagnostic log file which you can get it as a zip file from the help menu as well as your e-mail address so that we can pin point other crashes it will be great. You can send it to prabakar.murugappan@autodesk.com.
Prabakar.
