I recall after you import a file, it automatically updates if the imported file has changed. I think it worked before... but for some reason it no longer updates itself. Do I need to turn this function on? or did something changed after the update?
Thank you in advance.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Reading your questions, i now realize that I was thrown off by the work import file. I assume you are actually doing an "Insert" in to a design. If this is the case then we do not have associative insert. So once you have inserted a file into a design there are no links to force an update when the parent file changes.
Autodesk Fusion
Join Fusion Insider
