Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Import dfx issue
4 REPLIES 4
cash7c3
482 Views, 4 Replies
Import dfx issue
When I import this file I get no errors, but when I open it in fusion 360 no elements appear, the file shows up empty.  Working fine in 2d programs here, what do i need to do to get files like this into 360 correctly?
4 REPLIES 4
innovatenate
in reply to: cash7c3
What application is this dxf file coming from? There appear to be some unsupported figures in the file. I need to research more to know for sure. Perhaps you could try a DWG format instead?
Nathan Chandler
Principal Specialist
cash7c3
in reply to: innovatenate
Thanks for the repsonse!  That file is coming out of draftsight.  DWG results in same problem.
innovatenate
Does draftsight have a command similar to explode? You may try exploding the figures if they are some sort of block. This may convert them to a figure type that is readable for Fusion 360. I'm not sure if this will work, but just a suggestion to try. Let me know if that helps.
Nathan Chandler
cash7c3
perfect, thanks!
