When I import this file I get no errors, but when I open it in fusion 360 no elements appear, the file shows up empty. Working fine in 2d programs here, what do i need to do to get files like this into 360 correctly?
Solved by innovatenate. Go to Solution.
What application is this dxf file coming from? There appear to be some unsupported figures in the file. I need to research more to know for sure. Perhaps you could try a DWG format instead?
Thanks for the repsonse! That file is coming out of draftsight. DWG results in same problem.
Does draftsight have a command similar to explode? You may try exploding the figures if they are some sort of block. This may convert them to a figure type that is readable for Fusion 360. I'm not sure if this will work, but just a suggestion to try. Let me know if that helps.
