We're designing a simple specialized cabinet. We laid out the side view in a sketch, using thin rectangles to represent 1/4" MDF board. We then extruded the rectangles to the proper depth, and voilà we had a 3D cabinet of the proper dimensions.
We decided to modify the design and I added a lid that slopes down from the top. Beauty, piece of cake.
Except… the point where the top board and the lid meet leaves a 45° gap as can be seen in the attached image. The purple hand-drawn lines represent my desire to modify these rectangle so thaty they come together without a gap with a nice 22.5° bevel (which ideally would bevel the extruded body faces).
How do I modify the sketch to extend the the lid and top so they come together with beveled edges? I can use draft to alter the lid and top bodies, but can't figure out how to alter the sketch.
Solved by jeff_strater. Go to Solution.
Hopefully I'm understandingt the problem correctly. What I would do is this. Starting from something like your picture:
Insert a line (any length) in the gap:
Then add an angle dimension between the two, and set it to 22.5 degrees:
Then, draw a horizontal line from the point on the right side:
and then another line from the point on the left to the endpoint of the previous line:
Is that what you had in mind?
Jeff Strater (Fusion development)
