How to join two sketch rectangles with bevel?
2 REPLIES 2
blackpuma
1174 Views, 2 Replies
We're designing a simple specialized cabinet. We laid out the side view in a sketch, using thin rectangles to represent 1/4" MDF board. We then extruded the rectangles to the proper depth, and voilà we had a 3D cabinet of the proper dimensions.
We decided to modify the design and I added a lid that slopes down from the top.  Beauty, piece of cake.
Except… the point where the top board and the lid meet leaves a 45° gap as can be seen in the attached image. The purple hand-drawn lines represent my desire to modify these rectangle so thaty they come together without a gap with a nice 22.5° bevel (which ideally would bevel the extruded body faces).
How do I modify the sketch to extend the the lid and top so they come together with beveled edges? I can use draft to alter the lid and top bodies, but can't figure out how to alter the sketch.
Tags (3)
2 REPLIES 2
jeff_strater
in reply to: blackpuma
Hopefully I'm understandingt the problem correctly.  What I would do is this.  Starting from something like your picture:
Insert a line (any length) in the gap:
Then add an angle dimension between the two, and set it to 22.5 degrees:
Then, draw a horizontal line from the point on the right side:
and then another line from the point on the left to the endpoint of the previous line:
Is that what you had in mind?
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
blackpuma
in reply to: jeff_strater
Jeff,
This was very helpful. I'm still learning the ropes and was able to create two correctly-beveled panels.
Thank you!
