Active Member
0 Kudos
How to add parts to an assembly?
384 Views, 3 Replies
04-10-2013 07:57 PM
lets imagine that I have make two drawng in seperate files. How do I add them both into a drawing and make an assembly?
This must be very simple, but I find no way of doing it!
thanks.
254 Kudos
Re: How to add parts to an assembly?
04-10-2013 09:23 PM in reply to: pCondylis
It is simple, but not very intuitive or obvious.  There is a little magnifying glass icon at the upper right of the window.
search icon
If you click on it it will expand to a search box.  You can type the beginning of the file name you want to add, it will search in the project and come up with a list- select the one you want and it will be placed in the drawing with a move tool active.
Unfortunately you don't seem able to browse- you need to have an idea of what the file name is.  And the process is hidden behind a non-obvious icon, rather than identified with text or a menu item. Easy, once you know how to find it.
- Ron
Retina 5K 27" iMac, 4 GHz Core i7, OS 10.10.1, 24GB RAM, AMD Radeon R9 M295X 4096 MB
Active Member
0 Kudos
04-10-2013 10:03 PM in reply to: Oceanconcepts
Thank!
Yes its quite obscure!
I was expecting that there was a hidden "place" menu item somewhere...
Employee
14 Kudos
04-22-2013 07:44 AM in reply to: pCondylis
We have a new dashboard we are working on and will make this workflow much easier once we roll it out. This is a very comon question and I agree not discoverable at all.
