I select Fusion 360 to make package plastic box.
But I can't find in help how to add vector logo to project.
I want make embossed logo on front of plastic package.
123D Design for example import only SVG and after resizing geometry breaks to set of straight lines.
You may try inserting an SVG file into Fusion 360, see below.
I hope that helps!
Ok! Tnx a lot!
But SVG imports whithout sizes maded in Illustrator.
How to resize to my sizes again.
Hmmm I found that only proportion resize, but how to set so example 5 mm width ?
I'd love to find out how to resize my logo as well. I have imported the svg into project but its so much bigger thatn my 2inx3in face I'm trying to put it on (so i can engrave it on aluminum) that it loooks like its in outerspace . Much appreciated !
You can scale a sketch: after you import your SVG, choose the scale tool and select the sketch in the browser as the Entity you want to scale. You can choose the point around which it scales, hit the X beside point in the dialogue box and choose a new point on your sketch geometry.
I understand that the default scale in Illustrator the default is 72 pt/in. If you just put 1/72 in the import scale box you, it will help you scale correctly during import.
I hope that helps.
