I noticed this odd behaviour which I'm not sure if it's considered a bug or not.
When using the hole command, if I were to click and drag the hole, it'll only snap on existing center point of a thru circle but if I were to draw a sketch and place a point, click and drag will not work, I can only click on the sketch point to position the hole accordingly, click and drag the hole will not position it. Not sure if it's a bug but I find the experience to be inconsistent?
https://screencast.autodesk.com/Embed/2fba3789-f34b-4a32-81c8-f8a9cc5fa3cb
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Solved by SallyYang. Go to Solution.
Thanks for reporting this issue and providing us the detail description with video.
It's a snap bug when Click&Drag the hole to reposition the center. I've filed a bug to development team to track your feedback and we will fix it in future releases.
This is as designed. When place a hole on plane or face, you can drag the hole originon this plane/face because the origin is not fully defind. But when you place a hole on a sketch point, the hole origin is already define. so we do not support draging the hole origin
Omar Tan
Malaysia
Hi Tan,
Thank you for your report. we have confirmed this is a bug. The "drag to reference" and "click reference" action behavior is inconsistent.
Hi Tan,
Sorry, I misunderstood your meaning. What you mean is not placing a hole, but selecting hole reference. When place a hole on a face, it will support snap the key points on the face as reference. This is usually achieved by click or drag. Here you can snap a sketch point by click, but can not by drag. This is the bug. perhaps we need to forbid sanping a sketch point as reference. We will fix this. Thank you for reporting this.
Daniel
Not sure if this is related but I am having no luck at all with the hole tool. I can place a hole on a face of a box and can't seem to select the edges to add references. I deceided to create a sketch point and snap the hole to the sketch point. I went back and edited the sketch point and the hole did not stay with the sketch point.
I don't know why you can't select the edges as reference when place a hole on a face. Could you please send me your model?
We usually can select one or two edges as the references.
The snapping to a sketch point is just a UI behavior which is not assiciated. That's why you see the hole didn't stay with the sketch point.
In other words, it's the bug we talk about which I said may need to forbid this behavior(snappin to sketch point).
Daniel
Well now I am getting it to work just fine, so I will have to assume the probem was just me 🙂
Hmm, if I'm not mistaken, if I were to draw a sketch point and "snap" a hole to it, it'll move when I reposition the sketch point. Which is great as this allows me to sort of have a sketch where all the holes is drawn and I'm able to reposition the holes just by moving my sketch points.
The issue that I have is that, when creating a hole, I can't click and drag to snap onto the sketch point, but I can click and drag to snap onto existing extruded round profiles. To me, it's just an inconsistent UI behaviour.
Get what I mean?
Omar Tan
Malaysia
Sometimes, if the hole is too close to the edge, it'll fail to find reference, what you can do is to move the hole slightly farther away and it should be able to find the reference. Hope this helps
Omar Tan
Malaysia
Thanks I bet that was my problem. However, the face that it was on was not much bigger than the hole on any sides so I guess I could not get far enough from the edge to get it to work.
Omar Tan
Malaysia
