what does ground means?..i was watching a tutorial and he slected a body and right clicked and selected "ground"..what does ground do in assembly?
Solved by jeff_strater. Go to Solution.
Yes, that is correct. It will lock the component's position with respect to other components. So, for component dragging and joints, that component will stay locked. But, yes, using Move, with the Object type of "Body, sketches..." selected, you can still move a Body within that component (or a sketch, or work geometry, etc).
Jeff
When I have a grounded component, why can it still be moved with move? This doesn't make sense to me???
Thx!
As Jeff explained, there are differences between bodies and components. Sounds like you are moving the body within the envelope of the grounded component.
So within the confines of a component, bodies have freedom of movement.
Why move a body? Well, some bodies are only used as construction tools. Picture a patch body that is used to split a solid body. Those should both exist inside the same component. You may need to move the Patch body to affect the split location. Just one example.
Lets take a close look at the Move command and notice the options.
The Move command defaults to body selection. So there are a couple ways to do this "easy".
To move a component, instead of body.
1. Select the component in the browser and RMB to get Move. The component option is selected for you.
2. Double click the component in the design itself, this selects the component. RMB to Move, and the component option is selected for you.
3. Start Move command, switch to Component option, pick your component.
4. Drag the component, if you have "component drag" turned on.
There are a few more ways, but you should get the idea.
Please let us know if you have more questions.
