I'm having trouble putting together a large assembly composed of smaller subassemblies. Even though the subassembly is fully joined (you can drag it around and all the parts come with), when I import it into the larger assembly try to apply a joint to it, the joint only applies to the specific component of the subassembly. The bearing will be joined to its shaft, but it will leave the wheel attached to it behind.
How do I get the subassemblies to stick together? I'm sure there's something obvious that I'm missing...
