Late last night I saved a project, and Fusion 360 hung eternally with the spinning coloured ball (OS X). I let it do that for 10 or 15 minutes before forcibly killing Fusion 360.
This morning using the A360 app on the iPad it said that the file was not available, so I try to open the project in Fusion 360, and when I try to open that project, it hangs eternally with the spinning coloured ball. I see no option other than forcing Fusion 360 to quit.
This is rather annoying as it's the first project we'd like to turn into a physical object, rather than a practice project.
Ideas?
This happens on a new model iMac and a Macbook Pro.
Solved by Phil.E. Go to Solution.
See if the file is saved in your offline cache.
Thank for replying!
Conclusion:
It looks like the hanging problem has been resolved. However, I'm not sure what's up with Fusion insisting that there are uploads in progress. These projects are quite small. Even if I let fusion sit open for hours, the upload message which coincided with the original problem remains. (This may, of course, be a separate problem that's merely coincidental.)
For what it's worth, I have started seeing exactly the same message "You have 3 data uploads in progress which will be stopped if you quit now…." on trying to quit Fusion- even after opening no files. This after having a string of PLM 360 errors.
When you get this message - Click on NO (to not quit) and at this point can you please capture the diagnotic log files (Help - Diagnostics Log files) and send it to rajkumar.ilanchelian@autodesk.com? We have fixed a similar problem before and would like to find more details here.
Also do you login to your accounts on multiple machines?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Rajkumar,
Yes, I log into different machines: my laptop, my home workstation, and my work workstation. Two are running OS X. The other is running Windows 7.
If I encounter the problem again, I'll do as you've instructed.
Thank you for your kind attention.
