I noticed that in Fusion 89.98 degree will read like 90D
Obviously this is problematic.
Files Rhino Fusion:
https://drive.google.com/file/d/0Byzv_NlyKp_2VGYtZVpwRmZNNm8/edit?usp=sharing
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Hi Claas,
I believe this is just due to the angular precision being used. By default, Fusion displays angular measurements to 1 decimal place. You can change this in the Preferences, under 'Unit and Value Display'. The 'Angular precision' setting here lets you display angular values with anything up to 9 decimal places:
Setting this to 2 decimal places should give you the same accuracy as Rhino.
However, this does highlight the fact that the 'Precision' setting inside the Measure command does not seem to be appying to angular measurements. I'll follow up on why that is and whether we can change this behaviour.
Thanks!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
