Yesterday I installed the latest version of Fusion360 (2.0.10.43) and started to work with them with no problems. As you know, the interface (and other things) have been changed but suddently, today, when I opened Fusion360, the interface looks the same as the previous version.
What happens? I uninstalled Fusion 360 adn reinstalled last version but the result is the same, old interface.
Thanks in advance.
Solved by inaid. Go to Solution.
Ok, if you load an older design the interface changes to older version interface. If you create new design the interface maintains with the new look.
I've poked around the interface and I can't figure out how to convert a file to history based modeling. Is it possible to convert to do this?
Yes, but it's well hidden. Right click on the root component at the top of the browser. The last item in the menu should be Capture Design History, assuming you start in the direct modeling environment.
