I'm using Autodesk Fusion 360 v2.0.1193, and since tonight, Fusion takes around 5-8 minutes to start up. When it eventually does, it only runs in offline mode?
I've tried restarting the application, restarted my Mac? Any ideas what could be wrong?
Solved by innovatenate. Go to Solution.
While in offline mode, you may use the export archive command to create a *F3D file that is stored on your local hard drive:
1. Open Fusion 360 (Offline Mode is okay)
2. Open the design
3. In the main menu, select Export Archive
4. Save the *.F3D file on your local hard drive.
5. Back-up the archive file to a safe location
For the connectivity issue, is there anything different on your network that would prevent Fusion 360 from accessing the web (e.g. a new router, updated security software/anti-virus)? Are you currently able to access the internet on that machine?
