Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Force a dialog box (i.e. INSPECT/MEASURE) to remain on-screen @ all times?
2 REPLIES 2
mknickles
518 Views, 2 Replies
I'm constantly glancing @ object dimensions and I have plenty of screen real estate.  I want to keep some dialog box windows open 100% of the time.  Is there a way to "pin" them so they remain open @ all times?
2 REPLIES 2
joel.palioca
in reply to: mknickles
At this point we don't have this capability.  This seems like a great suggestion though, what you can do is you can add your idea to our IdeaStation which allows other users to also help vote up the importance of ideas like this.  These ideas help us to tailor the product for what our users want to have.
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/idb-p/125/tab/most-recent
If you see yourself using a command often you do have the ability to add an item to the Toolbar if it isn't already there, this may not solve what you are looking for, but its great for often used commands.  You can do this by clicking the Add to Toolbar button, on the right side.
Cheers,
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Autodesk, Inc.
bjorn39YVB
So now, eight years - or so - later, was this ever implemented?
