Let me start of with I love F360 and what the team is doing with it, however there's just still many features that need to be added, bugs need to be fixed and performance optimization that needs to be done before I can use it as my day to day CAD software.
Here is one of them, and this is related to graphical performance. I'm comparing this to SolidEdge ST5 which was released in 2012 but surprisingly it beats F360 in the framerates. I honestly thought F360 being a new software will be better but sadly it doesn't.
The model I'm showing below is 100% drawn using F360 and some of the electronic parts is downloaded from the respective manufacturer part. I exported the file afterwards into my daily CAD software.
https://screencast.autodesk.com/main/details/01240083-5864-4564-9f1c-9f7df65a0ca7
This is how it looks like in SolidEdge after I import it via STEP, notice how much smoother the model is.
https://screencast.autodesk.com/main/details/056bd069-c1ec-4971-ac37-6e55b0fda19f
I decided to test the file again except this time, I imported the same STEP file into F360 thinking perhaps the paramaters or design information in the model is slowing things down, doesn't seem so. F360 is just slower.
https://screencast.autodesk.com/main/details/d4166007-e182-4640-b5e3-ca877eb48663
Now if you wonder how is my usual working environment in F360, I attached another short video to show how F360 generally runs with a "small" assembly.
https://screencast.autodesk.com/main/details/8cb9aa6b-dcdb-447c-b0a9-51ff42df8cde
I've tried turning off all of the effects and it turns out, only the imported STEP file framerates is improved whereas on the original file, no framerate improvements can be seen.
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Chengyun
I only run everything in simple and the problem is still there. The UI needs further redraw speed improvement when it calculates and highlights areas.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Claas Kuhnen
Tan et all, thanks for taking the time to highlight and engage on the topic of performance. Performance is something we want to excel at in Fusion. Performance is a bit of a complex topic as there many variables involved and easy to assume what might be happening. On the other hand performance is measurable to help have an objective conversation and address problems we have. To that effect we are working on a script for you to run which will provide frame rate/timing information, graphics card and graphics settings info to help the conversation. Hopefully we can get it out today or tomorrow.
Meanwhile there might be some misunderstanding of the importance of GPU which I would like to correct. Stepping back a bit and picking up on a point Trippylighting made, performance characteristics and the variables involved are different whether we are talking about interactive viewport graphics or operational performance
On interactive viewport graphics GPU plays a big role along with the software algorithms. In Fusion all interactive viewport graphics is done thru the GPU. We don't do any software rendering as it is slow without GPU acceleration. The reason for this was we wanted customers to have a realistic experience while working on their projects. We did make an assumption that computing power is available for this experience. So GPU memory is important for a good experience. Where we are starting to see the challenges is video cards with lower memory (512 MB). The question I have is should we work towards supporting lower video memory cards. We will probably have to provide a different experience by default if we detect these type of cards. Looking for your feedback.
That said it looks like we have issues with the spacemouse which we are looking into.
So Claas for interactive viewport graphics I would like to understand your comment that GPUs were used many years ago better.
On operational performance, this is how fast you can access your data, upload/translate files, how fast can I go back and forth in the timeline or add/move geometries in the sketch etc. There are two factors involved here. 1) software architecture/algorithms 2) network bandwidth
While we have our set of tests on performance I would really appreciate if you can share models with performance issues mentioned in this thread. Sketch solve and timeline performance were the two areas mentioned here. On the data access/upload front, we are aware of challenges in our architecture and are actively working on addressing them starting with the next update in Jan.
Prabakar.
Claas Kuhnen
There is a way today that you acn measure graphics performance in Fusion360. In the Fusion360 View menu, select "Show Text Commands". In the text command panel click on the "Txt" button to enable text commands. Enter the command "Diagnostics.InteractivityMeter /Show".
This shows a panel that includes the current Frames Per Second rate for the scene.
It would be good to hear some FPS numbers which people contributing to this thread are seeing. Also include infomation about the OS, computer and graphics hardware if you know it.
-- Scott Morrison
Claas Kuhnen
I am assuming when you say 3D cube it is the view cube on the top right corner of the Fusion canvass. Is my assumption right?
When you say "zomming via mouse with mouse over object" are you using the mouse wheel to zoom or using the zoom command from the view navigation toolbar or the space mouse?
If it is the space mouse we are looking into it.
Prabakar.
Claas Kuhnen
What framerate do you get when you use the mouse wheel to zoom when the cursor is not over an object?
Claas Kuhnen
I can confirm that zooming is:
a. Generally slower than rotating . Using the cube about 50%.
b. With the mouse cursor over geometry 3-4 times slower that rotating.
Observation: this thread seems to mostly apply to users with Mac. On a PC GPU performance can be had cheaply. On Mac notebooks or iMacs ther is no option to replace the graphics with anything higher performing, so for mac users this is a prticularlt important issue.
Here is a littel screencast. Keep in mind that the Screencast software eats some performance. Farmerates in simple mode with all Effects turned off and no grid mostly maxed ourt at 60fps for rotating the geometry.
https://screencast.autodesk.com/Embed/Timeline/97f1bb0d-d549-4c07-aa45-a08e5b48fee9
Claas Kuhnen
I posted an idea on the board to be able to turn off the constsnt highlighting as it can be a real annoyance in some cases. Aside, of course from being a bit slow at the moment 😉
Claas Kuhnen
Changyun > I’ve changed it, but I’m not sure what difference should I see, everything seem to work the same?
Omar Tan
Malaysia
Hi All,
Thanks for all the posts. I think we have got a much better understanding of the performance problems discussed here. Based on that, I want to share some of my thoughts on these problems, as a graphics developer on Fusion team.
1. I think it is clear that the original problem(compared to SolidEdge) in this thread raised by O.Tan is related to the SpaceMouse. The team has been investigating why it causes this kind of difference from the standard mouse. We will try to fix it asap.
2. It sounds like one of the most painful performance issues is "zomming via mouse with mouse over object". My observation is this happens mostly likely on the low video memory graphics cards. I am not using this as an execute for the Fusion performance issue but let me explain that as best as I can.
As I mentioned in the previous post, the "Normal" prehighlight/selection style effect is actually a pretty heavy graphics effect and it could consume a lot of video memory, especially when your monitor resolution is relatively high. That is why I suggest you switch to "Simple" selection style effect if your video memory is not high, which is much more economical in terms of video memory consumption. If your video memory is high(e.g., 2048MB or above), you probably won't notice the difference (probably this is why O.Tan didn't see the difference). But for low video memory cards, typically using the "Simple" selection style effect will improve the highlighting performance pretty obviously. O.Tan mentioned that probably Fusion should do this kind of switching automatically if the GPU memory is low. I think that is a good point and we will manage to do that in Fusion future release.
In Claas's case, he mentioned that even he switched to use the "Simple" effect, the performance was still pretty bad. To explain that, I would like Claas to help try one thing. Claas, if you reduces the size of Fusion window to a smaller resolution(e.g., 900 * 500), I believe you can feel that the viewport performance will be much better. There are two reasons: (1) the smaller window size means less GPU memory is needed for Fusion. (2) The smaller window size means less GPU pixel shading computation(all the material shading in Fusion is done at the pixel level). Claas mentioned that "specifically the more I zoom in the more performance slowdown". It is also due to the same reason. When you zoom in the objects more, the objects will cover more pixels on the screen and there will be more pixel shading computation.
You may wonder why Fusion takes more video memory compared to other software. One thing I want to point out is in Fusion all the materials are physical based materials and all the environment lightings are high dynamic range(HDR) lighting, which is fundamental for us to make the material rendering to be realistic in Fusion. However, this also means when we represent one pixel color, each color component of RGBA should be stored as a 32 bit "float" instead of a 8 bit "byte" so we can handle the HDR images correctly. You can imagine if you have a 2000 * 1000 window size, a single color buffer will take 2000 * 1000 * 4 * 4 = 32 M video memory, not to mention the color buffers used by various visual effects like ambient occlusion, anti-aliasing, etc.
That said, we do realize that Fusion viewport performance is becoming a challege for us on the low end graphics cards. Right now we are having some discussions in the team to see how we can improve this and then provide a better performance experience on those cards in the future Fusion releases. We also hope you can continue to provide us the good suggestions and feedbacks in this regard.
Chengyun
Autodesk Fusion Team
Thank you very much for the explanation.
However I cannot confirm your suggestion.
If I minimize the window to the smallest size, switch to wireframe mode, and zoom via mouse,
I can on the MacPro with a GTX 570 bring Fusion down to 9fps when I zoom in closely.
the image below is a time delayed screenshot moving mouse to screenshot software so the FPS went from 9 to 18fps.
Also in this test I noticed that when using the zoom button in Fusion and with enough zoom in I slow down the UI to 10fps without anything highlighted.
Also another observation is that what ever quality setting I use (preferences and display settings) the FPS effect remains the same.
With low settings and with high settings the result stays the same.
So it seems to me again that simply the UI code and how it redraws the screen is problematic and that the used hardware honestly does not matter much.
I have the same experience on an old 512MB card and a newer 1.5GB card. I am getting in the next days my GTX 970 and I am very sure that with the 4GB card
the experience will be the same.
I noticed in some other applications similar problems in the past, when zooming in the UI simply slowed down a bit, Fusion however really tanks.
Claas Kuhnen
Hi Claas,
The zooming workflow in wireframe mode you mentioned in your latest post might be another example that Fusion is a little more baised on display quality over the performance. Fusion internally has an Level of Detail(LOD) mechanism, which is when the object is far from the eye point, the geometry will be rendered using a coarse level of mesh data while when the object becomes closer to the eye point, it will be rendered with a finer level of mesh data. The purpose/target is the more closer you look at the objects, the more finer details will be presented to you. The various levels of mesh data is generated on the fly when doing the zooming workflows, which could cause the drop of frame rate. Furthermore, the generation of mesh data is done directly through CPU and GPU is not involved in this process. I think that is the reason you didn't see the difference across the machines. We do have some ideas to use the GPU to accelerate the tesselation of the mesh data but that is a long term plan and we haven't done much work on that direction.
I think the performance discussions in this thread bring up a very important question for Fusion, in terms of how we should balance between the display quality and performance. One idea we are discussing in the team is we think it might be a good idea that we introduce two rendering modes in Fusion: Performance and Quality. In Performance mode, we can suppress all these expensive effects and totally focus on providing the user a good performance experience. For the low powered machines, this new "Performance" mode could be much more reasonable for the Fusion users. We would love to hear what you think of this proposal.
Chengyun
I see what you mean. If I set Alias to the same precission however it is pretty still pretty fast.
It is quite common if the frane drops below a certain point to simplify the display and the update only after scrolling / rotation is done.
Personally I was just quite stunned to see that even with such a basic model I had the fps tanked.
I would expect this only with a complex design only.
One computer is an old core to duo 3 GHZ the other is an 8 core Xeon.
So after all this discussion I think the ideas Fusion tries to do are nobel, color accuracy etc for shaded mode and precise geometry
rendering for wireframe, but the endresult from my point of view of a user is rather not optimal when I want to work in details.
This is not a deal breaker, but for me when such a basic model tanks, than I really do not want to know how Fusion will perform when
I work on a complex design.
Claas Kuhnen
Just to confuse the issue further, I have seen performance improvements with the Space Navigator (basic version) in the last updates. This is on a geriatric 27” iMac using full screen and with only 512 mb of video ram, so a graphically underpowered system for the screen size. I’m not using very complex models, and they are mostly analytics, so maybe I’m not really taxing the system, but my FPS rarely drops below 56 or so, even spinning and zooming the model wildly.
Previously I had seen drastic slowdowns using the Space Navigator when the Measure tool was selected, but no longer. It's very zippy.
