I have been trying to modify a connection piece we are using and for some reason the exstensison we are doing are only showing up in short sections. It seams as if there may be some issue with drawing having two sets of units but I cant find anything.
Would you be willing to share the file so that I can take a look at it? This isn't the desired behavior nor is it normal, we want to make sure we understand what is happening so that we can get it fixed.
You can share it by exporting an archive file .f3d and attaching it here or you can email it to me at the email below.
Cheers,
Looking at the model there is certainly something wrong. I am sending this to our dev team to work on a fix for a future update. In the meantime if you want to extrude the entire distance like you first attempted to, instead ofhaving the extents as a distance, choose the "to" option and select the face at the end that is already extruded that far. This should be a workaround for you, though you may need to alter some of your features that come after this extrusion.
Cheers,
This model looks like it was converted from a different format or from a history-free model. It may be that there is some unexpected scaling factor in an component's positioning transform. How was this model made? Did it come from a different format? This information would help.
Hi, The data was inported from a DWG file type but I am fairly sure it was created origionaly in a solid works or other type progeam.
I think it should be a bug. I've logged one (FUS-15512). We'll try to fix it in later update. Thanks for reporting and uploading the issue file.
