Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Edit an Edge Set?
2 REPLIES 2
paul
294 Views, 2 Replies
Edit an Edge Set?
Is it possible to add edges to an existing edge set when editing a fillet?
2 REPLIES 2
deyop
in reply to: paul
After starting a fillet command or editing a fillet feature you can hold down the CTRL key (Win) or Command key (Mac) and the edges will be exposed and you can modify the fillet selection.  We refer to this as "roll-back" and can actually be applied to any command where you need to modify the original input.  Shell is another example.
paul
in reply to: deyop
Perfect!
