Is it possible to add edges to an existing edge set when editing a fillet?
Solved by deyop. Go to Solution.
After starting a fillet command or editing a fillet feature you can hold down the CTRL key (Win) or Command key (Mac) and the edges will be exposed and you can modify the fillet selection. We refer to this as "roll-back" and can actually be applied to any command where you need to modify the original input. Shell is another example.
