if I work with TS objects this amount is enough to turn my MacPro GTX 570 into a stop motion cinema.
Switching only to select TS body and not edges makes it fast again.
So it looks the interface still has radical issues with performance when an edge rendering effect is on.
All other visual effects are turned off and in prefs things set to fast not good.
The interface selection lag is really a nightmare. sometimes a lot of click commands are executed somerwhere
else my mouse I moved to then.
Thats prone for accidents.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
The main limitation on selection speed will be the Simple or Normal option in the Graphics section of Preferences. If you are mostly T-Spline modeling it is probably best to set this to simple all the time in the Selection display style. There is an option to change it when the system detects a graphic speed limit (Degraded selection display style). That being said we always degrade the highlighting in preference to speed when you hit a limit of 100 edges. In your example case you may be just under the threshold of 100. Once again for fastest speed set display style to Simple.
Hi Paul,
I have that already set in the preferences by default as anything else is not really workable with.
The browser and selection lag is a real serious issue that should be addressed as it is very frustrating
to wait for Fusion in the 3D view to do the part edge highlighting before the mouse can interact with
that I have in the browser.
And it seems that the main problem child here is TSplines:
Body mode 3 seconds
Face mode 17 seconds
Edge mode 25 seconds
I just did a test with settings set to high and the edge selection was the same time till the browser got responsive.
Now I understand this file has many parts, but if Fusion should really empower designers to work
with complex shapes in T-Splines the screen refresh has to improve as only simple shapes seem
feasable to model but nothing of the complexity I work in.
Sometimes just drawing the selection rectangle already has minimal screenlag when working with TSplines.
The moment I jump into Breps it is fine. So something inside Fusions interface render engine gets a big
speed drop when just even seeing TS objects on your screen.
I attached the Fusion archive for you to test if you want to.
Claas Kuhnen
Thanks for sending the file for comparison. I am getting similar results when testing the same file including the window box delay. We agree that selection performance needs to improve and we are actively pursuing solutions. Thanks for your patience.
