How to position and joint two faces (components a, b) x distance from each other. Component a is ground.
Solved by jeff_strater. Go to Solution.
using the Joint command (not "As-Built Joint), pick the two components, and specify an offset value by dragging the arrow or entering a value:
Hope this works for you.
Jeff Strater (Fusion development)
