Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
distance joint
1 REPLY 1
EliteEngineer
1687 Views, 1 Reply
distance joint
How to position and joint two faces (components a, b) x distance from each other. Component a is ground.
Tags (1)
1 REPLY 1
using the Joint command (not "As-Built Joint), pick the two components, and specify an offset value by dragging the arrow or entering a value:
Hope this works for you.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
