Disappearing History
17 REPLIES 17
Message 1 of 18
mark2t
3426 Views, 17 Replies
I've tried out the new copy component feature where the history of the component is also copied, which is a must have, but I am really confused with whats going on the history timeline. Where I used to have design history I now have none. There is a collapse toggle beside features  which I thought were to collapse groups to save room on the timeline, but when I toggled one of them, my design history for that component just dissappeared, and I have no clue how to get it back. Please see the notes on the screenshots to see what I'm referring to.
17 REPLIES 17
Message 2 of 18
mark2t
in reply to: mark2t
Also, going through undo's does not bring back the history timeline.
Message 3 of 18
CGPM
in reply to: mark2t
This may be too simple but what is displayed in the time line depends on what component is active.  If the top base component is acive then " I think" everything is visible in the timeline.
Message 4 of 18
mark2t
in reply to: CGPM
No, that is not the case. When I make the component active there is now no history.
Message 5 of 18
joel.palioca
in reply to: mark2t
Are you able to attach the original file prior to the disappearance of the timeline?  Unless you dissolve or delete a node there shouldn't be a reason the nodes disappear, since it sounds like you have already checked out the active node piece.  If some of the nodes are being lost we want to make sure we understand what is happening so we can get it resolved.
Cheers,
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Message 6 of 18
mark2t
in reply to: joel.palioca
Ok, I am having major issues with getting back to a point where the history for this component still exists. Every version I upgrade to the newest from this morning when I started having this issue has no history for this component. I've tried restarting my computer to see if it's some kind of memory cache issue, but no go. I've tried exporting and downloading a version I believe to be the correct one, but after downloading, Fusion gives me an error message that says it cannot open local files? WHAT???? Tell me what the point of downloading the file is then? How do I open the one that I exported as the archive? How do I delete the ten versions I made trying to get to one that still has history? I'm sure you can tell that I'm VERY frustrated with how this program is working.
Message 7 of 18
mark2t
in reply to: mark2t
Hi Joel,
I've invited you to my test project where I've made a simple box and dropped it into a new design to start an assembly. I then copied this component and pasted it as "New" into the same design. I then modified that instance of the box. The original box had a group of it's features, that when I collapsed it's toggle button, it's feature history disappeared. Also, the second box, on opening the design a second time, moved back to the origin, though when placed as a copy, I had moved it. Initial moves on placement should "stick" until formally mated to something.
Message 8 of 18
innovatenate
in reply to: mark2t
I'm sorry that you are hitting so many road blocks. I haven't seen this issue myself. Can you describe the workflow that you have been using in this file? Is it something that I may be able to use to reproduce the problem?
There is a tips in the tips section of the forum that may help with how to access an older version.
http://forums.autodesk.com/t5/post-your-tips-and-tutorials/how-to-roll-back-your-design-to-an-older-...
Also, the cannot open local files warning is most likely caused by trying to open your archive file directly (e.g. double clicking on the file). You should use the upload command to open it in Fusion 360. See the below tip for more detail on this.
http://forums.autodesk.com/t5/post-your-tips-and-tutorials/data-exchange-in-fusion-360-build-2-0-129...
I also wanted to add some screen shots to this to show how the Active component can filter the Timeline:
VS.
At any point, did you toggle the Capture Design History?
Nathan Chandler
Principal Specialist
Message 9 of 18
mark2t
in reply to: innovatenate
Hi Nathan,
Yes, I know all this. No I have not switched off capturing design history.
Please explain the logic behind downloading a file you can't open? What's the point?
Please read my above post that explains my workflow on this. It is repeatable.
Message 10 of 18
innovatenate
in reply to: mark2t
Fusion 360 is a cloud based CAD product. You can make localized back-up files, and work from a local cache, but the data is stored in the cloud. For this reason, you need to first upload the file before you can open it in Fusion 360 or work from a local cache.
I've been trying to figure out the steps to reproduce this issue, but I'm not having much luck. See below:
I also tried this with the Set Two.f3d file that I have from another post, but no success so far. Is there anyway you could make a Screencast recording of the issue?
You can download and use Autodesk Screencast for free from the below website.
https://screencast.autodesk.com/
Thank you in advance for any insight you may have.
Best Regards,
Nathan Chandler
Message 11 of 18
mark2t
Hi Nathan,
I made a simple box and dropped it into a new design to start an assembly; as if I had this part before and am reusing it in a new project.  I then copied this component and pasted it as "New" into the same design. I then modified that instance of the box. The original box had a group of it's features. When I collapsed it's toggle button, it's feature history disappeared. Also, the second box, on opening the design a second time, moved back to the origin, though when placed as a copy, I had moved it. Initial moves on placement should "stick" until formally mated to something.
https://screencast.autodesk.com/Embed/e65ba1c3-5507-47a1-a84d-13c89311ebca
As you can see from the screen cast, the first box's history is gone and now no longer editable.
Again, no luck copying and pasting the "Embed" code in to the HTML tab.
Message 12 of 18
innovatenate
in reply to: mark2t
I was overlooking the Paste New command, entirely! Thank you for the Screencast, that cleared everything up.
Let me report this issue to development and I will reply with what I find out.
Thank you again for posting this and for your patience getting me to see the light!
Best Regards,
Nathan Chandler
Message 13 of 18
innovatenate
I wanted to let you know that it looks like there's a fix pending for this issue.
Nathan Chandler
Message 14 of 18
calebc01
Please forgive the thread necromancy, but I'm having problems with disappearing features from history.  Clicking and holding a history feature and slightly moving it, as if to drag it, causes the feature to disappear on release.  This is true for extremely small movements that shouldn't change the position of the feature in the history (presuming that reordering operations is even a thing).
I have a part that is essentially ruined, and I'm afraid I'm going to have to go back and redesign the thing.
Message 15 of 18
TrippyLighting
in reply to: calebc01
As usual, please share your design.
Peter Doering
Message 16 of 18
calebc01
in reply to: TrippyLighting
Link here: http://a360.co/2fhRJJj
The item with the issues is "Body6."  I deleted the component created from the body while trying to fix the history issues.  The body is comprised of three extrusions total, but I can't seem to find any of those features in the history, and can't edit them.
I have another, more involved design that has the same issue, but it's more easily seen above.
Message 17 of 18
TrippyLighting
The first thing I usually check in any design containing more than one component is whether there are sketches at the top level and what they do.
In this case there are too many, so I am going to refer you to Fusion 360's R.U.L.E #1 for some important reading material when it comes to efficiently working with Fusion 360.
In the meantime I'lll see if I can answer your actual question 😉
Peter Doering
Message 18 of 18
jcsantilli
I have been working with fusion for a while but how to copy and paste is still a mystery to me.
for example I copy and paste the active object, but if I want to position the new component x and y inches to the lower right corner of the part below. How do I do that?copy&paste.png
