Not sure how this one happened, I am thinking user error.
I wanted to split up a part using a plane created from a sketch line using the Patch -> Create -> Extrude feature. This worked fine in another file with a similar model. But for some reason in my current file, the whole list Patch -> Create is cut very short. See these two pictures.
How do I get my features back?
Solved by TheCADWhisperer. Go to Solution.
The list of parametric surfaces is shorter than the Base surfaces. (It seems they add additional functionality each release).
Simply click on the icon to create a Base feature and then you are good to go.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Thank you both for replying. With your images I was able to sort it in a minute CADWhisperer! Some proof / eye candy below.
Now about these features being hidden, I have only started using Fusion360 for about a week, so bear with me. What you both are saying is that when in Design Mode (note sure when and what this is) and I see the timeline, certain features are not availible? Since I am learning to use this program it is kind of worrysome that I might be not seeing certain features that I could be needing.
How are these parametric surfaces different then the Base surfaces is there a good resource / video to learn about this. I am eager to learn and spend time on this, but I am a bit baffled at the moment.
@casperhofstede wrote:.... I am eager to learn and spend time on this, but I am a bit baffled at the moment.
We have decided that Fusion is not ready for the classroom yet. I spent a couple of weeks going through the tutorials and doing some of my prior work from other CAD programs in Fusion and was a bit baffled myself about how it is supposed to be "easy". I suspect by next year it will look quite different than it does now as they tie everything together and I will have to "unlearn" everything I did this summer.
Having come from an R&D background it is very misleading having "grown-up" with your new baby and understanding how to communicate with it and passing the baby to someone else to understand. As it matures, I am sure it will communicate with the user much more efficiently.
BTW - nice picture - it looks like you are finding your way around.
Claas Kuhnen
Claas Kuhnen
This one caught me out today, I found that by toggling Design History tracking On & Off got them to appear & disappear. Obviously toggling that back & forth is a dangerous game to play. I'll see if I can hunt out the base feature tool mentioned and if it can be combined with history based modelling.
F360 does excite me, but so did Inventor Fusion... which ultimately I really disliked. I can see the eagerness behind this product and want to see it suceed.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
