Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Cutting leaves artifacts
2 REPLIES 2
nkloski
332 Views, 2 Replies
Hmmm..another problem with this simple model.  Sculpted a completely solid body.  Added in a Solid box, tried to Combine/cut but artifacts are left over, even though the cutting tool was way oversized.
Here is before:
And after I do Combine/cut (leaving no tool behind, just a simple cut) I get this:
With those jagged lines showing up in all renderings as well:
This is a simple cut with only two objects in the timeline, just the sculpt body and the simple box body, no other complexities I can think of?
Thanks!
Nick Kloski
2 REPLIES 2
jeff_strater
in reply to: nkloski
that looks like a bug. It could be just graphics, or those could actually be leftover geometry. If you could send the model, we can investigate it.
(WRT to the other thread (Fill in curved space) - we are thinking along the same lines, I see...)
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
nkloski
in reply to: jeff_strater
I tried it with another model and that problem did not happen....it might have been something transient, so if this persists I will post something here, but for now, let's leave this one as it is! thanks!
Nick Kloski
