Hmmm..another problem with this simple model. Sculpted a completely solid body. Added in a Solid box, tried to Combine/cut but artifacts are left over, even though the cutting tool was way oversized.
Here is before:
And after I do Combine/cut (leaving no tool behind, just a simple cut) I get this:
With those jagged lines showing up in all renderings as well:
This is a simple cut with only two objects in the timeline, just the sculpt body and the simple box body, no other complexities I can think of?
Thanks!
Nick Kloski
Solved by jeff_strater. Go to Solution.
Nick Kloski
