This is quite simple to draw, not sure why it leaves a surface on one side and not the other.
https://screencast.autodesk.com/main/details/696a2297-bdc5-4b2d-95b2-91eeadb9ed73
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Solved by Mike.Zhang. Go to Solution.
Seems a problem, just can't reproduce it on my side.
Could you attached the F3D file into this topic, or you can send a mail to me by: jiangang.zhang@autodesk.com
My guess is it'll be an issue if the diameter is 20mm and the cut is done at 10mm, probably some intersection glitch?
Omar Tan
Malaysia
Hmm, you can zip it if you find another issue next time.
Thanks.
Omar Tan
Malaysia
OK, I can reproduce it with your model. Will log a defect to track it.
Thanks your information.
