Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Although T-Splines have topology and can be manipulated in a manner similar to polygonal models they also have the ability to convert to NURBS geometry. Each face of the T-Spline can converted to a 3rd degree Bezier surface. When we visualize the model or apply curvature combs to the T-Spline we are actually evaluating the 3rd degree Bezier surface. This is the reason the curvature combs are displaying differently than splines which are 5th degree.
The display is accurate however the relative smoothness is a point of argument. The question becomes whether it is smooth enough for the purpose it will be used either for visualization or manufacturing. The curvature comb emphasizes the relative smoothness but the practical application of the results is what is important.
We are planning on changes in the future to ensure curvature continuity at the star points. We have also discussed raising the degree of the T-Spline to 5th degree however there would be perfomance and interaction comprimises that may not justify making the change.
We certainly are interested in your comments.
Claas Kuhnen
I think you can continue to trust the combs but consider if you were to make a degree 3 curve in Alias. The comb will look similar to the T-Spline comb. When you need additional flexibility you will have to add edit points to the curve. At those points you will see the same type of curvature "kinks". Is the T-Spline smooth? I won't try to persuade you only let you know that degree 3 surfaces have been used successfully in manufacturing for years. From the long time Alias user perspective it may be suspect though.
When it comes to the converted BRep surfaces they also are degree 3 so they will show the same curvature comb characteristics.
Claas Kuhnen
