I am trying to create little holes of a Speaker Box like this
I can only find the circular pattern and rectangular pattern. How do I Create all the little holes around a shape or inside a shape so that it fill all the area with small cuts evenly throughout the whole shape. This is my model so far and I would like to make holes in a Slot Shape on the side:
Solved by Cathy.Wang_Autodesk. Go to Solution.
Thanks for using Fusion!
You can try to use Path Pattern, you can select a edge or sketch lines as a pattern path. For Pattern Object, you can select faces or feature.
Enjoy it!
Thanks for your reply. So just to confirm, I have the Slot Shape as shown above that needs to be filled in with lots of little circles. Where should I draw the first circle before I use Path Pattern. Can you please explain further as I am still not quite fully sure.
Thanks your patient!
Currently, Fusion have no feature to do the pattern on faces. So we cannot patten the object on the cambered faces directly.
We have two ways to finished the model 🙂
One is using path pattern to create the model. Another is using decal to put a picture on the model.
Enjoy Fusion360!
