Solved by innovatenate. Go to Solution.
If you convert your bodies into components, you can use Joints to control their position in relation to one another. I'm not sure if that would help, but thought I would mention it.
If you create a sketch, you can project 3D geometry into the 2D sketch plane. You can then start creates sketch entities and dimension them from your projected figures. Would that work?
Hope this helps.
