Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Create as component or join with body?
2 REPLIES 2
codefoster
245 Views, 2 Replies
I created these braces for some added strength in this design. Right now they are components. My reason for going that route was so that I could change one and the other would change. That's a small advantage. Are there advantages to joining them with the body? If so, how do you join the bodies of one component with another?
2 REPLIES 2
rhudaynath
in reply to: codefoster
As these (Ribs) are part of same design (for adding strength), it can be combined to make it as a single solid body.
For this, you can use Model->Modify->Combine command and select base design as 'Target Body' and these Ribs as 'Tools' then say OK with Join option.
To make it easy for modify you can try using sketches/parameter to drive that Ribs size.
Rhudaynath
Software Engineer
codefoster
in reply to: rhudaynath
Like a charm! Thanks.
