Trying to do a simple sub assembly of a bearing plate in Fusion. When I try to rotate and place the assembly in its final location all of of the components come apart in a fairly random fashion. The components are assembled with ridgid constraints, and I have also tried grounding them. Not sure what I am doing wrong but its getting frustrating.
https://www.youtube.com/watch?v=vMu-2wcGGlc&feature=youtu.be
Sorry I know that is an awful description. I just needed to get something up quick. Like I said I used ridgid joints between all of the componets which I think may be part of the issue. I am still trying to get used to how fusion constrains parts. Coming from Creo everything just feels foriegn to me haha. But basically I need to constrain the bearings and bushings to the bolt as a sub, then constrain the sub to the plate. And the whole thing to the extrustion.
I think I got why you got this weird result. The default move option is Move Bodies, sketches..., this is a body level option, it'll not affect the component positions, so caused this result, it's not a issue.
You should select the Move Components option when you using Move command on the assemblied parts.
You can try it again, if this resolved your problem, please accept as solultion.
